Block heater in a 2555
Tim Snellgrove
01-22-2007 05:23:41
Does anybody know where a block heater would go on a 2555? I have looked around and did not see any obvious freeze plugs or fittings and such. Don't need it often here in East TX, but sure could have used one this last week.
Tim Snellgrove
01-24-2007 05:37:47
 Re: Block heater in a 2555 in reply to Tim Snellgrove, 01-22-2007 05:23:41
Thanks for the replies. I could not find a fitting like y'all have described, finally found a mention of a block heater in the operators manual. It looks like some kind of separate element that gets plumbed in with heater hose somehow.
buickanddeere
01-23-2007 20:01:33
Glad to here somebody using a block heater instead of beating the engine with ether.
Bill_Utah
01-22-2007 14:52:28
third party image
Tim:
This is what it looks like on my 2355 installed from the factory.
R. John Johnson
01-22-2007 06:51:39
Tim
On our 2755 it is one the left side of the block towards the back. There is a larger rib in the block casting and it goes in a port on the underside of the rib. There is a picture in the operators manual showing it installed. In the picture there is a clamp holding three of the injector lines nearby. I would take a picture for you, but the tractor is in the shop getting the clutch replaced
Hope this helps
John
