JD 1520 shifting problems
Colin Duke
01-21-2007 18:09:45
Just replaced clutch in a 1972 JD 1520. Now the only gears I can get it to go into is reverse and 1st; and forward I and 1st (1st being 1 of 8 speeds). And this is only if you put it into I or reverse first then shift the right lever to 1st. It grinds like crazy in anything else.
If you have tractor shut off, it will shift fine. What do I adjust? Any help would be appreciated as this tractor belonged to my father who recently passed away. It has great sentimental value as I spent many a fun hours on that tractor with my dad.
Thanks
cannonball
01-22-2007 06:33:55
 Re: JD 1520 shifting problems in reply to Colin Duke, 01-21-2007 18:09:45
after you put clutch on flywheel did you setup clutch...all the fingers must be set..did you have flywheel turned, best money you can spend..
MAY GOD BLESS THE USA
Colin Duke
01-24-2007 09:50:18
 Re: JD 1520 shifting problems in reply to cannonball, 01-22-2007 06:33:55
Thanks for the input guys. How do I setup the clutch? The shop manual gives no advice except how to adjust the play in the pedal. Do I have to split tractor again to do setup? Any directions, manuals, links, etc. would be appreciated.
I notice there are two or three plates on the side where you can see the clutch and the fingers. Is this where you adjust?
CharlieMc
01-22-2007 05:49:42
It sounds to me like the clutch is not releasing all the way. Although I am not sure why it would work ok in 1st gear, unless its just easier to engage with the clutch dragging.
Charlie
