2010 JD crawler
DeereDiesel
01-21-2007 16:36:34
I have a 1965 John Deere 2010 crawler/highlift, gas that im going to try and get running. after sitting for 6 years. It was parked because it died in the field one day. It does turn over just fine. kinda slow but fine. the carb has been rebuilt it has decent compression in all cylinders. The problem im having is the ignition. it has a universal swithch to turn it over and other terminals that neeed wires to make it run. it also doesn't have any wires to the distribitur or coil. I need to know what wires need to go wear to hot wire it with the switch i have. I also need new points. for some reason it doesn't have any points in it and i can't find any for it. the distributer doesn't have a name plate or model plate. Could this be a Wico. distributer???? ive tried to get points for a delco remy and they wered even close. if any would know what points to get or has a 2010 with the same no number of distributer that could give me a part number i would greatly appriciate it. ( I mean it doesn't even have mounting hole for a id tag on the distributer) Im sure once i get spark to her she will run again. Thanks to everyone who took the time to read and help. Thanks again.
THINGS NEEDED: LIST OF WHAT WIRES GO WHERE TO GET SPARK( wire to witch end of coil. and witch one to distributer.etc) PART NUMBER OF POINTS THAT MIGHT POSIBLLY BE NEEDED OR MAYBEE AN IDEA OF WHAT DISTRIBUTER I HAVE SO I CAN GET SOME
jdemaris
01-22-2007 05:42:04
 Re: 2010 JD crawler in reply to DeereDiesel, 01-21-2007 16:36:34
1010 - 2010 distributors:
Early Delco distributor - i.e. 1112577 has a clip-on cap and four-advance weights inside.
Takes breaker set LD AT14465 or HD AT14466. Delco scew-on cap distributor # 1112623 or X-23226 takes breaker set # AR31818. Wico distributor # X30091 with clip-on cap, two centrifugal weights inside - takes condensor
# AT15929 and points AR12003. Note that the Wico cap-clips are not held by screws - just
by hooks. Prestolite distributor IBT-4101 with clip-on cap, two centrifugal weights - takes breaker
assembly with plate for early models - AT14683 or for late models AT21719. Note - the
cap-clips on the Prestolite are held on by screws.
