1958 720D pto ( I think I broke it)...Please pardo
Scott Griffith
01-21-2007 06:39:45
I recently removed and painted the pto clutch pedal and after re-installing it, I tried to engage the pedal by depressing it forward with my big foot without the tractor running. I think I may have forced it as it felt as if I sheared a pin or key. Now the PTO goes clunk clunk clunk then quits spinning... I had a tiller attached. I engaged the pto and heard a rattling sound, hence the clunk rattle noise. I then lowered the spinning tiller to the ground and it stopped spinning. So What should I look for? Did I shear a pin of some sort? Is it out of adjustment? I seem to have read about this problem before on this site, but cannot find it.
Scott
Mike M
01-21-2007 09:48:39
 Re: 1958 720D pto ( I think I broke it)...Please p in reply to Scott Griffith, 01-21-2007 06:39:45
Having it running or not does not matter for the foot pedal on the 2cyl. models. So it was broke or about broke before. It does matter only if you are shifting the little lever by the shift tower that you need to use a cresent wrench on the flats to move have the engine off for this.
The models you should have running to engage the clutch pack are the 1010 and 2010 on these you can shear a roll pin that you have to tear it all apart to replace.
As for what broke ? your going to have to go in for a look.
