36 B Carb Question
CalJim
01-20-2007 20:53:39
Hello all,
Can I run a DLTX 34 on a 1936 B? I am sending
in my DLTX 10 to be rebuilt but would like to
know if the 34 is ok to use in the meantime.
Thanks to all. CalJim
Duane Larson
01-20-2007 21:06:28
 Re: 36 B Carb Question in reply to CalJim, 01-20-2007 20:53:39
CalJim,
It has a larger bore (1 3/8" vs 1 5/16") than the 10 but will work on your unsB. You might be careful and lean it out or it could run rich.
Mike M
01-21-2007 05:58:35
 Re: 36 B Carb Question in reply to Duane Larson, 01-20-2007 21:06:28
Even leaned out to where it will still run, the A carb. on a B will still tend to foul out the spark plugs. You can run it on the B ,but I'm betting if you try to do much with it your going to have fits with your spark plugs.
Duane Larson
01-21-2007 08:02:03
 Re: 36 B Carb Question in reply to Mike M, 01-21-2007 05:58:35
Mike,
I believe the DLTX34 he wants to put on is for the early styled B from 96000-200999.
Mike M
01-21-2007 09:58:01
 Re: 36 B Carb Question in reply to Duane Larson, 01-21-2007 08:02:03
I got confused when I saw that 1 3/8" as I didn't think a B was that big ? Can't say as I ever needed to measure one either ? If he is putting a B carb. on any model B I doubt he will notice much difference and it should work out ok.
