A far as I can tell, Deere has always been happy to replace parts, "supercede," the parts book often says. Its sure that different divisions probably each picked out a 16" 6 bolt wheel with a slightly different offset, load rating, and wheel maker. Some probably picked a wheel that wasn't reversible, and others with practically the same specifications had double coned bolt holes or 12 bolt holes for reversibility, again otherwise with about the same offsets and load rating. Some came with holes for wheel weights, some didn't. As time passed, parts that were similary were consolidated into a common part number ignoring the visual differences between manufacturers and having near enough offset to work in all the applications, and a great enough load rating for all the applications. I'm sure that 16" 6 bolt wheels were used for nearly every implement with tires as well as nearly every tractor with tires. Didn't matter whether the implement and tractor were Deere, Case, IHC, MF, Ford, Cockshutt, or Avery. Then besides Deere specifications, the SAE had standard wheels too with these same variations. With F&H and Electric Wheel and others specializing in wheels, its likely Deere bought most such common wheels by lowest price bid that met the Deere specifications. At the most they had the maker stamp the Deere part number before applying the Deere yellow paint, but they specified the load rating, the rim diameter, width, and offset, the bolt circle/center hole, and whether or not there were holes for mounting wheel weights. Sometimes they took a stock SAE specication wheel and painted it themselves when production demanded faster delivery than a custom number could accomodate. And so long as the tires didn't rub on tractor spindles or machinery parts, the wheel was right, even if not exact to the Deere part number. Then there were options in many implements of coming without tires or with various sizes of tires, tractor too, whether front or rear that took different sizes of rims. So I think insisting on a particular wheel part number isn't traceable to factory production. Gerald J.
