 There are at least three ways. You can go to a rebuilder or a salvage yard for the pieces. From a rebuilder the valve and remote connection will easily go for $500. And you still need the pipes and fittings. Deere may still have the parts which can be identified from the parts book. Places like Shoup (www.shoupparts.com) sell doublers that plug into the existing single remote and electrically switch between two hydraulic loads and they run close to $500. You can tap the system pressure at the elbow right in front of the brake pedals and return oil to the transmission oil filter cover and mount a closed center valve on the right fender with as many circuits as you can find room for connectors out back. Deere made an oil filter cover for the 2640 with a hole for that purpose. That's a standard connection for a loader with its own valve. I put a flow restrictor valve in the plumbing for mine because 5 gpm (like the regular remote valve is set for) is all my loader needs. The oil filter cover runs some $65 and the valve from $100 up, plus hoses, fittings, and something like a dual pioneer set of couplings that will connect under pressure that runs $100 to $150 depending on how good you shop. I'd reverse the handle and mount the valve under an arm rest with all the plumbing going down. The picture above is of that pressure tap and my pair of circuits that I use for a loader and sometimes a back hoe on my 4020. This works and has for several years. I don't have an extra remote, but I get tempted to replace the loader valve with a triple valve to have one for another remote port and on with float for the loader when pushing snow, but so far I've not done that. Gerald J.
