Break-in powder???
Tx Jim
01-20-2007 05:16:18
I have a neighbor that installed JD piston,liners & rings in a 4 cyl. crawler engine. Engine now has excessive blow-by,hard to start & only 150 psi compression. It has been run 30 hrs since overhaul. Has anyone ever used break-in powder or Boraxo? Thanks,Tx Jim
Henry M
01-20-2007 19:08:01
 Re: Break-in powder??? in reply to Tx Jim, 01-20-2007 05:16:18
Tx
Don't really sound right to me. I did a two cyl 420 with overbore, pistons and all. I just started it up and used it like always. It runs fine.
I donno
skipper
01-20-2007 18:34:42
Tx,
Any chance the rings were installed upside down? That will give similiar results sometimes.
Skipper
James2
01-20-2007 15:25:29
Yes, Bon Ami or Comet will work and Cat did recommend using it for engines that the rings were hard to seat. Problem is that it wastes over a third of your ring/liner life. Try the JD breakin oil and only the powder if nothing else will work but a rebuild. If you use the powder, change the oil as soon as you feel the rings have set, this will minimize the wear problem.
Gerald J.
01-20-2007 10:58:57
I have a JD service Bulletin, probably about 1970 where they say they changed the type of rings and the new rings don't need to be ground in, so don't use break-in powder on them. I think these new rings were chrome plated. Plain cast iron rings might still need grinding in with the break-in powder.
Gerald J.
donmyeil
01-20-2007 09:41:43
Did he use breakin oil and breakin procedures for the first 100 hours??? If he let it set and idle for long periods he has probably glased the cyl's or did he overload the engine and score the pistons?? Proper break-in is very crucial to a new engine. Doesn't sound good to me.sorry
msb
01-20-2007 08:11:26
Deere used to include it(Bon Ami) in their overhaul kits in the early 60s.Came with a small caplug about 3/16" in diameter.We put one capfull in each intake port in the head just before installing the intake manifold.
adsma
01-20-2007 05:43:42
Did he install breakin oil after putting in the new piston/liner kits? JD part# TY22041- 1 gal. size. If not he better soon or he might be overhauling the engine again here shortly! Drain the oil and change the filter. Install the breakin oil and run the tractor under heavy load for 100 hours to seat the rings. Do not add oil unless it goes under add. Then drain and install the regular engine oil unless it is still taking oil. If it is still taking oil, go another 100 hrs with the break in oil then change it and go to the regular oil. If it is still taking oil, serious repairs might be needed again.
Tx Jim
01-20-2007 09:06:02
 Re: Break-in powder??? in reply to adsma, 01-20-2007 05:43:42
When did JD start recommending installing break-in oil with overhaul? What's in oil to aid ring seating? They didn't say anything about oil way back when I was a service manager for a dealer. Thanks,Tx Jim
wilamayb
01-20-2007 09:44:03
 Re: Break-in powder??? in reply to Tx Jim, 01-20-2007 09:06:02
I dont think it is whats in it, but what is not in it that counts. It is pretty thin, and not slick. It has almost a dry feel kinda like diesel fuel. I dont know exacty when deere started with it, but it is in response to the incredible oil that is made by todays standards. As example cars used to need an oil change every 1500 miles, now some mfg. are reccomending 7000 miles. Of course some of this is due to engine improvements, but good oil is also responsible.
Of course you cant have your cake and eat it too. This good slick oil that prevents the wear also prevents piston rings from ever being set. Compression will stay low and oil consumption will be a problem, just like a worn out engine.
machinery-man
01-20-2007 05:33:50
55 Chevrolet had this problems with the 265 engines and I understand dealer secreatively used bon ami. An older mechanic friend said they also used bon ami on diesel cat engines. How much I can"t say but he said they poured it in the intake....guess some crude methods are sometime necessary...
