1936 John Deere B project
Russell S.
01-19-2007 17:27:41
I pulled the old girl to the shop today. its time to start the restoration. It is a 36 B in pretty good shape. This is going to be my first JD that i restored so I need to be steered in the right direction. I"ve restored on the red side four times now.Anyway, The pistons are stuck but I think that is the biggest problem. All metal looks good even the wheels. Can anybody help me start in the right direction? What do I need to do first? Thanks for all your help.
las vegas
01-19-2007 19:08:51
 Re: 1936 John Deere B project in reply to Russell S., 01-19-2007 17:27:41
before you take anything apart, get yourself some parts, repair, and operators manuals. You'll never get anywhere without 'em. THEY'RE EASY TO WORK ON, THOUGH!
Obviously, you got to tear it down to the engine to get to those stuck pistons. What I would do is drop every fluid and then remove the steering shaft. Then you can take the hood off with ease. Then you can pull the block after you've gotten all the manifolds and carb and head stuff off. Then just pop open the crankcase cover which holds the steering pedestal up. remove connecting rod caps and then withdraw the block with the pistons in it. Set the block upright somehow and pour diesel fuel in it. Set the diesel fuel on fire then take a 2 pound hammer with a hard wooden block and beat the sh*t out of the pistons. They'll come out if the engine wasn't too stuck.
ENJOY. Taking it apart is a lot of fun.
