620 starting problem
Milt Michigan
01-19-2007 16:15:00
Having a starting problem with 620. Battery appears to be OK. Turns over very slowly even in warm weather. Does 620 have compression release during starting?
buickanddeere
01-20-2007 14:33:01
 Re: 620 starting problem in reply to Milt Michigan, 01-19-2007 16:15:00
What is the voltage while cranking between the starter body and the power stud going into the starter motor? What is the spark timing at slow idle?
fixerupper
01-20-2007 05:49:45
How long has it been cranking slow? If it's been doing this for awhile I doubt it is the battery because it would have failed completely by now. The ground strap does seem to corrode pretty fast too and if it still has two 6V batteries the cable between them seems to want to corrode in a short time. My guess is starter. Could be as simple as worn brushes. Just had the starter out of a 630 that had been cranking slow for awhile and the center armature bearing had worn through the screws that held it in place so the bearing slid back and was grounding against the windings. I fixed that and threw in some brushes and turned the commutator and it spins like new now.Jim
John VB
01-20-2007 04:59:29
As mentioned already, make sure you have good electrical connections to the starter, especially the ground. My 620 was turning over slowly. I had a new battery and good connections. I rebuilt the starter and it now turns it over great. I replaced the busings and the switch. One of the busings that Deere says is the proper one, isn't. The shaft will not fit in it. I had to have somebody hone out the busing for me. Good luck.
CLW
01-19-2007 16:51:13
You say the battery "appears" OK. Try another known good one. Also check and clean all connections at both ends of battery cables and if the + cable grounds to the battery box check that the box has a clean ground to the frame. Then check the connection at the starter.
SM in Wi
01-19-2007 16:45:42
A 620 does not have compression release. I can start my 620 even when it's very cold beforeit turns over slow. I think you need to take a look at the starter.
CHRISFROMSOLITUDE
01-19-2007 16:44:29
Make sure you are getting 12v to your coil when you are cranking. There is a wire from the starter switch on the starter itself that will provide 12v to the coil during starting only. If that wire is broke it could not start. Hope this helps a little and let us know how it turns out.
BushogPapa
01-19-2007 16:38:22
They crank pretty slow, even in the summer...!!
As long as it keeps turning, it should start...!!
Ron..
