AR Manifold replacement
Frank
10-29-2003 20:41:49
The gasket on the intake manifod on styled AR is leaking and needs replacing. Which is the easiest route to take on this job. Manifold bolts look like some will probably twist off.Does the head have to come off to do this job or ? Thanks Frank
Mike M
10-30-2003 06:22:58
 Re: AR Manifold replacement in reply to Frank, 10-29-2003 20:41:49
I usually pull off the cyl. head as I think it is easier to remove than the hood ,tank,and governor and fanshaft to get clearance to lift up the manifold off the studs. I have also found that most can use a valve job anyhow and any broken studs and bolts are best drilled out with a end mill in a milling machine. And if the gasket surface is bad as is the case in most later 2cyls.with the 2 piece manifolds as in the 50,60,70 etc. it is easy to surface at this time.
John T
10-30-2003 05:31:59
Frank, been there done that and got the T Shirt more than once and it can be a tough job. First, the head may not have to be removed at all, it depends on how many studs you get out without breaking and the condition (flatness and lack of pitting) of the heads surface where the manifold mates.
If it has studs with nuts, heating the nuts with a torch usually allowws for their not too difficult removal from the studs. As much as possible, heating the nut around its perimeter but less on the stud/center expands the nut but doesnt soften the stud so badly it twists off. A good 6 point socket or maybe an undersized or a metric size until you get a good bite on the nut is essential. Its best to use shock and vibration (hit wrench end with hammer or an impact wrench set at lower torque to not break the stud) rather than a dead hard pull Ive found.
However, that sure dont mean the manifold will then easily lift up off the head. Once the nuts are removed, several days of soaking with PB Blaster or some use Kroil Penetrating Oil to try and penetrate the manifold hole to stud surfaces can help. Soaking and occasional hammer tapping to try and get the Penetrant between the manifold and studs takes patience. If you cant get the manifold off but can get it partly pryed up and raised sufficiently, a hack saw blade can be used underneath the manifold to cut the studs. The darn studs often get so rusted to the manifold they wont allow her to rise up off the head. If you use heat, remember it softens the stud, so let it cool before you torque the stud or it easily twists off.
Once manifold removed, if you have to dril and tap any studs, get their surfaces smooth and flat so you can use a punch to get an accurate center mark then start with small bits and progress up to the size to use a tap. CAUTION DO NOT drill any deeper than the old hole cuz you may drill down into water passages. If theres parts of the stud above the head, you may be able to weld a washer in the center to the old stud, then weld a nut to the washer, then extract it.
IMPORTANT NOTE If the manifold on its to head surface isnt smooth, I always take them to a machine shop and have them planed nice and flat and smooth which gets rid of pittign or unevenness. If the head has to be removed, it also can be smoothed down.
I use high temp anti sieze on new hardened studs, some use teflon dope or tape also on the threads, and stainless steel or brass washers and nuts up on top and torque down, then allow a good warm up, and then retorque and maybe once more after a long hard use. Have the manifold and head surfaces clean and dry and smooth.
Hope this helps some and its interestign to read how others tackle this job.
Post back or e mail [email protected] with any questions.
Good luck n God Bless ya Frank
John T Nordhoff
Ralph WI
10-29-2003 21:14:55
I helped an experienced JD mechanic do mine about 10 years ago. Got the head out of the frame by twisting it and our tongues just right. Using a torch and penetrating oil still had to drill one stud.
