30 Series New Generation II Tractors
TD
01-19-2007 09:13:37
Just wondering, any speculation on the 30 series New Generation II JD Tractors will they be some what collectable, or are there some that are already?
Thanks in advance,
msb
01-19-2007 11:58:05
 Re: 30 Series New Generation II Tractors in reply to TD, 01-19-2007 09:13:37
Collect them?? They are my main tractors.All the comforts of home without the magical voo doo computer junk that will eventually be very hard to repair or replace in my opinion.
G/MAN
01-19-2007 13:38:01
 Re: 30 Series New Generation II Tractors in reply to msb, 01-19-2007 11:58:05
I understand your concern, but the electronics on the "new" tractors are some of the more reliable systems on the machine as a whole. Heck, 50-series tractors introduced electronics to the Deere Waterloo line, and they've been out for 25 years now. The electronic systems are no more prone to failure than the regular electric systems on your 30-series tractors - the lights, HVAC controls, gauges, etc. In fact, they're less prone to failure, since many of the switches and sensors in an electronic system are solid-state - no moving parts to wear out or break. Many of the mechanical systems on a 4430 are much improved and easier to service when they're switched to electronics. It takes several hours to remove, rebuild and reinstall the hitch valve on a 4430 - complicated mechanical linkages, adjustments, wear points, etc. A 4555 with an electronic hitch uses two solenoids, half a dozen potentiometers, a controller and some wiring to do the same job and does it much more effectively. Electronic controls also make the mechanical systems much more reliable and efficient. Electronic engines are a perfect example of that - improved fuel economy, improved cold starting, more power, etc. I understand that a lot of guys don't like and/or fear electronics, but there's really no way to get around them in this day and age, especially when they're accessing this site via massive amounts of electronics.
msb
01-19-2007 16:10:17
 Re: 30 Series New Generation II Tractors in reply to G/MAN, 01-19-2007 13:38:01
My concern is for when the pool of people trained to service the newer systems are gone and when the parts are no longer supplied by mother Deere.I agree with you that the newer tractors are much more effecient etc.Common rail fuel system is a very good example of that.I could be wrong in my concern.Only time will tell.
G/MAN
01-22-2007 13:44:48
 Re: 30 Series New Generation II Tractors in reply to msb, 01-19-2007 16:10:17
Don't worry, we'll be around a lot longer than the guys that came up on 4020s. I'm 32 myself. We have around 14 technicians in the shop and I think there are only 4 or 5 guys older than me. And I think it will be quite some time - several decades - before Deere starts phasing out parts for the newer iron. Look how many new parts you can still get for a 4010 or even the two-bangers. Deere is smart enough to know that selling parts is gravy money.
G/MAN
01-19-2007 10:42:03
I think they will, to some extent. Are you going to see sheds full of them like you do with two-cylinders? Probably not, but considering that they're a milestone in Deere's tractor history, I'm sure that more than a few will be restored and collected.
Mike M
01-19-2007 10:23:39
I think some allready are. I think someone has allready gobbled up the gas engine models.
