Is it True..???
BushogPapa
01-19-2007 06:15:36
I want to get a Semi-Mounted 4x14" plow for my 63 and 720... I hear that with these, you don't get "Weight Transfer"... Is this true..??? Seems JD had a better idea than that...!!
Ron.
James2
01-19-2007 09:54:03
 Re: Is it True..??? in reply to BushogPapa, 01-19-2007 06:15:36
I have used a JD model 145A 4 bottom semi-mount behind the 730 several times. Took a little while to get confortable with it after having plowed many years with draft control/load sensing control and a mounted plow on other tractors. Thought about using a quick hitch as was mentioned by MSB, but decided that manual control was good enough. Might change my mind if I had a few hundred acres to plow. But you do get weight transfer. It just doesn't "automatically" increase/change depth when the pulling gets a little tough, you have to manually do it.
msb
01-19-2007 07:24:55
There is a special hitch for top link sensing tractors.A quick coupler will help transfer the draft to the top link.Not as good as the adapter,but it helps.
Mike M
01-19-2007 06:48:17
I would think you should get weight transfer by just lifting up on the 3 pt. some ? Maybe they are talking about the load and depth control not working correctly since it uses the top link on those tractors ? a later tractor has lower link sensing.
My cousin has used one behind his 720 and I think he liked it better than a fully mounted plow. He has no fluid in tires just some wheel weights.
BushogPapa
01-19-2007 16:36:32
 Re: Is it True..??? in reply to Mike M, 01-19-2007 06:48:17
Well you see, we had always used WD-45's with 4x14" semi-Mounted plows, and NEVER had the plow raise, as weight was transferred...the "Traction Booster" gauge indicated how much you were getting... I had always wondered when, people would talk about the AC's "raising the plow" when the pulling got tough..I guess they just figured that if the JD did it then every other one did, too..!! So...IF I used a 4x14" Fully-Mounted plow, the "Load and Draft control" will still attempt to raise the plow part way (if I don't drop the depth lever)..??? I kind of figured it was because I only had a 3 bottom plow on the 630.. Is there a way to adjust the lower links, so it won't lift as much in tough spots..?? I had the top link in the 1st hole from the pivot...!! (Least sensitive).. I guess I will be holding on to the WD-45..!!! Thanks..!! Ron..
Jams2
01-20-2007 15:38:57
 Re: Is it True..??? in reply to BushogPapa, 01-19-2007 16:36:32
I think the only thing the traction boost lever was doing is desensitizing the draft control. Don't know if the WD45 had one but the D17 did. Therefore when you have it set for high traction boost you have little draft control and are really running on manual or position control mode. Set the lever for low traction boost, you have more draft control and the plow will raise in tough going. I think you can install a bolt and block the top link sensing on the JD's, if you want only manual control.
Mike M
01-19-2007 18:29:58
Ron; I don't have much real world seat time using a plow on the 20 & 30 series 2cyl. not much on others either. I would think the answer can be found in the operators manuals of the plow and tractor. JD also has a service manual on those custom power-trols and it may explain in detail the operation of this load and depth system.
