4430 Engine in 4230?
PreciseFarms
01-18-2007 15:12:18
My dad is thinking has a 4230 in need of an overhaul. He has the option of buying a 4430 engine for $3000. It only has 115 hours on it as it served as it powered a generator in the basement of a bank for years. There are obvious issues with fuel lines, turbocharger, etc. Need advice on its feasability.
G/MAN - also...
01-19-2007 10:40:44
 Re: 4430 Engine in 4230? in reply to PreciseFarms, 01-18-2007 15:12:18
Before buying the engine, if it's going into a 4230 with a Sound-Gard cab, make sure the block has the mounting bosses for the A/C compressor cast into it. I don't know for sure if all the 30-series-era 404 blocks had those or not, so make sure. It's possible that industrial engines don't - so double-check. I don't think you want to get the engine installed and then find that there's no place to mount the A/C compressor.
G/MAN
01-19-2007 10:38:12
You need to look at that engine carefully. The fact that it's a turbocharged 6404 doesn't necessarily make it a "4430" engine. In fact, it's probably just a 6404T industrial engine. There may be parts swapping that will need to be done, etc in order to put it in a tractor - flywheel, possibly the water pump, maybe the crankshaft damper, possibly the oil pan, etc. I'd alse be very wary of an engine that old with that few of hours. If it was on an automatic startup system that started it ever so many days or every few weeks and allowed it to run long enough to warm up and get rid of the moisture in the oil from condensation, that's one thing. If it just sat there for months or years on end between startups, particularly if the basement is damp and cold, I'd be leery of it. Auto-start engines on gen-sets also usually go immediately to their rated speed on startup, which doesn't do them any good either. Depending on who does the work, what they charge and what all you have fixed, you may or may not be able to overhaul the existing engine for $3000, but you definitely won't have the hassle of swapping the engine. Were I doing the swap, I'd definitely pull the head off the "new" engine and take a look inside and also at the bottom end before putting it in the tractor. And I'd be replacing the front and rear main seals, rebuilding the water pump if it is the proper one, etc.
Walter Squires
01-19-2007 07:43:16
The turbo may not fit under the hood and the 4430 has a bigger radiator for cooling.
Mike M
01-19-2007 06:50:56
How bad is your dads ? if the crank is good you can just do an inframe overhaul the kit may be $1200-1500 ? and a hole lot quicker and easier.
Hayfarmer
01-18-2007 21:29:16
I can't imagine that it would be much of a problem. Basically the same block only built beefier. I would think the fuel lines should be the same.
Sam from WA
01-18-2007 15:41:36
It shouldn't be a problem. if i remember correctly, 4230s and 4430s were the same frame size. the engines should be the same, except for the turbo.
PreciseFarms
01-18-2007 17:38:16
 Re: 4430 Engine in 4230? in reply to Sam from WA, 01-18-2007 15:41:36
What about fuel lines, hoses, etc. How are they going to match up.
