Carburetor adjustment questions
Illinois Farmal
01-18-2007 15:07:41
I have a JD3020 with a M/S carb that I have been having constant problems with and have posted about here previously. It's been rebuilt and still constantly runs rich. My question is what are the initial settings on the adjustment screws? Right now both of them are turned completely in (cw) and the tractor still runs. If I back them out at all it runs even worse. Am I missing something here??? Thanks to everyone for all of their advice.
msb
01-18-2007 19:58:57
 Re: Carburetor adjustment questions in reply to Illinois Farmall, 01-18-2007 15:07:41
Where do you live in Illinois? If it isn't too far, you could run it over and I'll gladly take a look at it for you.Its probably one of two things wrong with the carb.I won't charge you anything except maybe lunch.lol.There weren't very many mechanics( we were called mechanics back then. lol) that understood those things even after they went to service school on them, when the tractors were new.
I am about an hour and forty five minutes east of the state line (I 74)and 2 miles south of IN 32.My e-mail is open.bob
Gerald J.
01-18-2007 15:38:58
Is there a manifold leak or a vacuum acceleration pump diaphragm leak?
How high is the float level?
Is the gasket turned right? How about the venturi?
Is there something missing like a main jet?
John Deere put out a service bulletin saying if you can't tune this MS, put on a Zenith. The 4020 shop manual has a large chapter on tuning the MS carburetor. I've not read it closely, since my 4020 came with a Zenith.
Gerald J.
Illinois Farmall
01-18-2007 18:09:34
 Re: Carburetor adjustment questions in reply to Gerald J., 01-18-2007 15:38:58
Actually there is a leak in the exhaust manifold. Would this make any difference? As you can tell I don't know much about carburetors. I haven't pulled it apart myself as I had it rebuilt by the dealer I bought the tractor from. If I had the money right now I would just go ahead and buy a Zenith but that's going to have to wait. Thanks for the input.
Gerald J.
01-18-2007 19:53:05
 Re: Carburetor adjustment questions in reply to Illinois Farmall, 01-18-2007 18:09:34
My 4020 ran a little rich when I bought it. Only put out a black plume about like a 1066 IH diesel, and a bigger black plume after idling a bit when sped up again.
I found several things. The ignition timing was off, the plugs were the wrong heat range and the wires were carbon and intermittantly open. But after I fixed those it still ran rich.
I found the top of the Donaldson precleaner was domed down from the wing nut having been tightened too much. That acted like a partial choke. I popped it back up and don't crank down on the wing nut.
I found junk in the air cleaner (paper) and intake pipe.
I found the choke wire was only pushing the choke halfway open because the sheath wasn't anchored near the carburetor where it was supposed to have been anchored.
The float needle and seat were worn, the needle was round, not pointed. It didn't slow the gas much.
The day I went to the Deere dealer to pick up the needle and seat, I asked the gasoline shop expert about it and he said, "If you haven't changed the float needle and seat, I won't talk to you. Come back when you've changed those. I have ways to make it run good." I pointed out I had them in my sack. I've not been back. Changing the needle and seat and making sure it closes and the float level is right according to the manual (probably I&T manual at that time) has made it run just fine. No adjustments needed to the mixture screws. But then they weren't taken out for a rebuild either.
A high float level (when the carbureter is upright) will make it run rich too.
There's often a screen attached to the inlet adapter and that often causes the opposite problem of slowing fuel. My neighbor's 2020 did that while we were trying to trim a tree in my back yard. I couldn't get 60 psi air to pass through the screen it was so plugged. That explained why it was so hard to start the previous winter and finally did when I choked it bravely.
I have to choke my 4020 most starts, even warm and I cut the fuel consumption from 400 gallons for 33 hours down to 250 gallons for 33 hours annual use, so I must have it as lean as it needs to be.
There is a bit of an art to carburetor adjustment. The governor hides the effects of adjustment too.
Its usually best to start the adjustment at idle, even to back out the idle speed screw on the throttle shaft plate and hold the throttle closed. Then adjust the idle mixture for the fastest running. If you let the governor act it will open the throttle when you get the mixture off and you can't detect the speed change. Worse, opening the throttle makes the high speed fuel circuit add fuel. The best scheme is to overpower the governor with a hand holding the throttle shut.
Then for adjusting the high speed jet, I prefer to do that under heavy load, usually a plow is what I've used in the past. Don't know what I'd use now that I've quit plowing. Maybe just full throttle accelleration in 8th gear on the road. Any way, a first approximation can be had by adjusting the high speed screw with the engine running fast and adjusting it for the governor closing the throttle the most. At that speed its harder to hold the throttle shaft still, but the governor will hide the effects of all your adjustments.
Then repeat the slow speed adjustment, and the high speed several times until the last time around there's no improvement. At that point you can set the idle speed screw back to specifications and you are done.
But if you don't defeat the governor at low speed and watch the effects of the governor at high speed you will get totally confused.
Gerald J.
