2940 hydraulic problem
Mike Grodecki
10-29-2003 20:40:12
HI: A friend of mine has a JD 2940 farm tractor,He is
having a problem with the hydraulics,after it warms up
it looses power and starts to chatter, like it is
starving for fluid.Reving helps with the power.Some
one told him that there are pipes in the PTO or trany
housing back by the rear axels that rub together and
leak causing it to loose presure.We opened it up and
found that one of the tubes had fallen off and was in
the bottom of the housing.Any Idea how to keep them in
place,or if thats the problem? Seems like they fall
right out.Has any one heard of this before? THANKS MIKE
david val
10-30-2003 00:14:12
 Re: 2940 hydraulic problem in reply to Mike Grodecki, 10-29-2003 20:40:12
the tube you found at the bottom of the axle area is probably a brake cooling tube and have nothing to do with the chatter. the 'tubes someone told' about are at the pto area (clutch housing in front of trsnsmission split line).
first thing to do in such cases it to check and clean the intake screen and replace the filter.
if that doesn't help there are a series of tests to be done.
david
