First Diesel?
OCB
01-18-2007 12:27:43
What was first the Dubuque Diesel. The 435 is the first listed but could there of been a 430 or 420 before the 435?
Was there more than the GM diesel experimented with? Clay
jdemaris
01-19-2007 06:21:16
 Re: First Diesel? in reply to OCB, 01-18-2007 12:27:43
From what I've read about the evolution of diesel-engine use in farm tractors, many companies, including Deere, were hesitant to produce their own modern diesel until a reliable compact fuel-injection system was developed. Deere, IH, Oliver, et. al. wanted to produce engine-lines that were capable of gas-or-diesel while maintaining the same engine footprint and basic block design. The older injection systems usually used huge in-line pump and governor systems. The Detroit two-stroke-cycle diesel was somewhat unique with it's separate plunger pump and remote governor. Technically, it is the first diesel invented - created by an English guy named Clark in 1879. Quite a few years earlier than Rudolph Diesel's first working diesel engine in 1894. Detroit Diesel used Clark's design. Vernon Roosa came up with the first marketable and successful rotary injection pump and his first major order for pumps went to Oliver-Cletrac in 1952. Deere built it's first diesel with the new Roosa rotary-pump system with the 1010/2010 series in 1960. In 1963, Roosa (Roosamaster) invented the pencil-injector and Deere adopted it for use. Roosa's company also sold rights to his pump design to CAV which makes their own version.
Motorken
01-18-2007 13:53:14
The 435 was the first Dubuque tractor with a diesel. It was a General Motors 2-53 2-cycle 2-cylinder with exhaust scavenging blower. The answer as to why it was the first is probably simple...Technology!
Back then diesel technology was not as advanced to yield a high horsepower rate vs/engine size in very small short stroke engines that would fit in the Dubuques. The dubuque gassers would generate better than 30 hp so, and to match that in a two cyl would require the size and stroke of the early Waterloo diesels. This was simply not possible in a 2-cyl,4-stroke, small engine at that time. By utilizing the time tested 2-cycle GM, Deere was able to get the right size powerplant and hp to last it until the new generation multi-cylinder models came out.
Chuck730DSE
01-18-2007 12:34:18
Not the expert here, but the 435 was the first JD diesel tractor from Dubuque. The engine was a detuned retro fit from GM (Detroit Diesel 2-53), the same engine in the 440 tractors and crawlers. I believe I am correct in stating that JD never built a vertical (Dubuque) two cylinder diesel engine.
Waterloo had a JD build diesel going back to the late 1940s. The R was the first production JD diesel.
Motorken
01-18-2007 14:12:24
 Re: First Diesel? in reply to Chuck730DSE, 01-18-2007 12:34:18
Adding to Chucks comments...Deere began experimentation in the early 40's with some X prototypes based on an extended AR frame. The issue for Deere was not so much in designing the motor, but designing a starting system capable of getting it running...particularly up north given the massive torque and compression of the Waterloo design. Most tractors back then were either hand crank or six volt. Even the 12 volt batteries then were weak as was starter and generator technology...Anyway, there is evidence that Deere worked in collaboration with Cat, or at least the engineers were drinking buddies as the first viable solution came in the form of the 2-cyl cranking engine used on the R which is very similar to that used by cat on it's early machines. The cooling system of the cranking engine and Diesel engine were mutual so the heat from the "pony" could help warm the Diesel engine prior to starting. Eventually by linking two 12's in series Deere was able to offer a viable electric starting system. There was also something I read about Deere researching a rotary type diesel engine, but apparently that never got off the ground
Chuck430C
01-18-2007 15:15:09
 Re: First Diesel? in reply to Motorken, 01-18-2007 14:12:24
And adding to the starting techniques, which is a world of it's own, even when they got to the 24/12 volt split starting system, about half of the 830s were ordered with the pony starter. My guess is that it was due to the cold weather starting advantages. The pony will not only heat the water in the diesel engine, but it heats an area of the air intake.
The pony motor is still the most unique way to start a two cylinder diesel engine.
