Abrasive blast Media
Farmer J
01-17-2007 17:27:36
What is the best type and size media to use in my sand blaster when restoring some implements. I have a bottom plow and ripper I want to get the rust off and repaint. There are so many different types of media out there I don"t know which to choose. Any suggestions would be greatly appreciated. I have a five gallon pressurized blaster.
Thanks,
Farmer J.
Duane Larson
01-17-2007 20:51:31
 Re: Abrasive blast Media in reply to Farmer J, 01-17-2007 17:27:36
Farmer J,
If you choose blasting with a media over electrolysis or a lye paste scheme like F-I-T uses, then I would suggest considering some non-silica media like Black Beauty coal slag. I have changed to that from sand, as the silicosis health issues are reduced - the health rating is basically triple 0. It works well, except for leaving a black pile as opposed to sand. Lots of blasting info out there, check Link for example.
Farmer J
01-17-2007 21:50:04
 Re: Abrasive blast Media in reply to Duane Larson, 01-17-2007 20:51:31
Thanks Duane,
I'll go to that site and check it out.
Information is much appreciated.
Farmer J
Duane Larson
01-17-2007 21:48:12
Another good reference regarding safety equipment and hazards is at:
Link
As you might have guessed by now, blasting safety is an issue for me - I had a friend die from silicosis after about 5 years of sandblasting bridges without proper protective equipment - the small, dust particles of sand are still sharp and small enough to be drawn into the lungs, where they scar the tissue and reduce the lung's ability to function. And of course, if you are blasting lead-based paint....
Farmer J
01-17-2007 21:54:16
 Re: Abrasive blast Media in reply to Duane Larson, 01-17-2007 21:48:12
WOW! didn't know that. Thanks again for the info.
I'll do some research before I get started. I did buy the hood and the proper breathing mask.
This is a great place for information. Thanks to people like you....
Farmer J
