2040 leaking steering column
atczeus
01-17-2007 11:05:04
Problem: 2040 tractor that has a very bad hydraulic leak just below the steering wheel. Dealer has replaced the entire steering column and did not help a bit. Any help would be greatly appreciated. Thanks.
Tom
Tx Jim
01-18-2007 04:23:00
 Re: 2040 leaking steering column in reply to atczeus, 01-17-2007 11:05:04
Have you or dealer checked stand-by pressure? I think dealer needs to redo the repair job! Tx Jim
deereford
01-17-2007 17:35:19
After some grief I discovered a hose was leaking. A simple fix.
PJBROWN
01-17-2007 15:02:41
This might sound funny... I knew a old person who had a 2940 that did the same thing and leaked by the shift levers also... He had too much hydraulic oil in it and it made way too much presure. He could not see the level line on the stick good so he thought more was better.
buickanddeere
01-17-2007 14:17:41
Too high output pressure from the pump? Is this a factory bebuilt replacememt or dealer rebuilt steering column?
