520 Rockshaft Removal
teater
01-17-2007 06:57:02
Hi there, in the process of 520 teardown and cannot budge the rockshaft/lift arm support. Don"t really want to bash and break the casting behind there. I"ve used penetrating oil for a week or so now, but my persuasive hammer doesn"t seem to be doing much. Heat will be the next option but I don"t have a torch available right now so I was looking for some suggestions. Thanks.
Mike M
01-18-2007 11:24:27
 Re: 520 Rockshaft Removal in reply to teater, 01-17-2007 06:57:02
Are you trying to get the cast arms off the splines of the rockshaft ? The ones I did I just removed the bolt holding them on installed another bolt I could ruin and put some spacers behind the arm and then give the bolt some good hits and pop the shaft out of the tapered splines.
