What is a good size JD to buy to play around yard
Dan V
01-17-2007 06:32:01
I am looking for a John Deere 40 hp and under,wide wheels to play around yard with.Something that is old under 1957 and cool looking.With a PTO and maybe hydrolics.Not really looking to do much with.I want something that will fit in garage.Is a JD 40 small?maybe something that size.What models should I look up.The model L is too small.Any suggestions...Thanks
HWarrior23
01-19-2007 19:34:27
 Re: What is a good size JD to buy to play around y in reply to Dan V, 01-17-2007 06:32:01
Where are you located? I know of some models of M"s, 40tricycle, 40 standard, and a 430 standard for sale if you might be interested.
Bruster
01-18-2007 08:25:51
It really depends on how big your yard is. If you only have 1 a. then you don't want a big tractor, since a 620 or630 are as big as a mid size car. a JD H is a nice size. I use mine on my 20 a. plot and it's great for pulling small trees, wagons, and just "puttin" around. They are small, nimble and you can find them with hydraulic, power take off, electric or hand start. a tractor should be allowed to work once in a while, you know? Sort of "stretch it's legs" Have fun looking!
Dan V
01-17-2007 18:09:56
 What about a 1958 620...????? in reply to Dan V, 01-17-2007 06:32:01
Are they monsters.I have one that is a few hours away that I might go look at.What is the difference between the 630 and the 620"s?Are they alot bigger that the 420"s?
diesel man
01-17-2007 18:54:18
 Re: What about a 1958 620...????? in reply to Dan V, 01-17-2007 18:09:56
well the only difference in the 620 and 630 is the sheet metal.. and a few odds and ins.. if it was me i would get the 630 but if you thought that the D was too big than the 630 is way to big
Perry County Farmalls
01-17-2007 15:52:00
435....detroit diesel....too cool!! Still the same size.
01-17-2007 15:53:40
 Re: What is a good size JD to buy to play around y in reply to Perry County Farmalls, 01-17-2007 15:52:00
sorry...newer than 1957.....but older than 1960
buickanddeere
01-17-2007 14:19:15
520 or a Dubuque. Why 1957?
Henry M
01-17-2007 13:31:54
Dan
Why set 57 as the year limit. They did not restyle and go to the motors that purred until 60. 59 and 60 had smoother sheet metal but still two cyl.
Lets take a hard look, when you get up into the late 420 you can be looking at 5 speed, live pto, real power steering, of course three point, oh and a snazzy cigarette lighter option with ignition key.
Anyway the M is the first kid out of the chute and then improvements started and went thru the 430 series.
Dan V
01-17-2007 14:49:18
 Aren't the 430's pretty big. in reply to Henry M, 01-17-2007 13:31:54
Aren't the 430's pretty big.I do not want to get too big.Like I said before when't to look at a D .That is way to big.I will start looking at the 420's and 430's.Which are good years?????
diesel man
01-17-2007 13:10:39
i would look for a B or A and or the anything but the M.
P Browning
01-17-2007 10:40:08
Dan -- You mentioned something under 40 HP, PTO & hydraulics, that will fit in your garage. The model H (39-47) fills this bill and you can learn more by paying a visit to the JD-H restoration site (below).
As you can tell by browsing the site some, there is plenty information available to back you up in restoration, either partial or full. (PatB)
Dennis in NC
01-17-2007 10:04:17
Look at the ao / ar and the bo / br
Dan V
01-17-2007 10:26:47
 Re: What is a good size JD to buy to play around y in reply to Dennis in NC, 01-17-2007 10:04:17
Is the ao / ar and the bo / br as big as the D
Dennis in NC
01-17-2007 11:24:03
 Re: What is a good size JD to buy to play around y in reply to Dan V, 01-17-2007 10:26:47
SMALLER BUT THE SAME TYPE STANCE. MAY LOOK THE SAME FROM FAR AWAY.
Richasrd J. Heath
01-17-2007 09:56:42
Convince my 40 that it doesn't have a "3 point hitch." 40 was the first JD with a 3 point hitch.
Ten-Twenty
01-17-2007 08:38:18
 How about a 1020 or 1520? in reply to Dan V, 01-17-2007 06:32:01
Dan V,
I know you said 1957 or older, but why not look at the 1020 (39hp) and the 1520 (46hp). Yes, they are somewhat newer but also SO MUCH more tractor. I have owned an "M", and two 420U's, and I now own a 1020 and 1520. The 1020 and 1520 are my choice, no question.
Dan V
01-17-2007 07:24:22
I looked at a 1946 D but to BIG ...Are the JD M's and 40's smaller
CPeter
01-17-2007 07:16:24
third party image
A 40S, 40U,420S or 420U would be my choice. 25 or 29 hp. nice size, 3 point hitch and PTO. "M"s are nice, but no 3 pt and tricky to get on and off and a littlle less hp.
This is my 420U with a Lord loader and home made lift on the back.
Handsome Jim
01-17-2007 17:05:26
 Re: What is a good size JD to buy to play around y in reply to CPeter, 01-17-2007 07:16:24
That's a slick looking outfit CP. Looks to be a safer way of moving a log than just dragging it.HJ
Vermont John
01-17-2007 07:02:09
I recently bought an M, and I LOVE it. I would agree that a 40 or 420 will be good too. This size tractor is big enough to feel like an impressive piece of JD machinery - a real tractor. Also, for a neophyte like me, the verticle engine seems a bit easier to deal with. The M exceeded my expectations in many ways. I put a 3pt. hitch conversion on it, too.
To give you a feel for size, I have a JD 420 Garden tractor, which is about as big a garden tractor as you can get. It carries a 60" deck and is powered by a 20h.p. Onan air cooled engine. This is not the toys they sell at Home Depot. To be honest, the M is not all that much bigger once you get used to it. However, it felt much bigger at first.
billde
01-17-2007 06:51:19
Models M, 40,&420. Model M did not come with 3pt but can be converted to 3pt. All would have hydraulics and pto but not live pto.
Wayne in Tn.
01-17-2007 07:46:33
 Re: What is a good size JD to buy to play around y in reply to billde, 01-17-2007 06:51:19
Correction. The M came out with something called a 2 point hitch. The 40-420 and 430 came out with a true modern 3 point hitch.
Mike M
01-17-2007 06:45:31
I'd say that model 40,420,430 would be a good choice and they have a 3pt hitch if you do need to do something with it.
