J.D. 730 Clutch Disk Drive Removal
Fireman
01-16-2007 10:47:00
Am trying to remove pulley so I can replace first gear reduction cover.I have gotten all the clutch out down to the disk drive,as per I&T manual I have screwed in the jack bolts tight and it doesn't want to budge off the crank.Have tried tapping the disk while trying to tighten the jack bolt to no avail.What am I doing wrong?Also can't see the V mark for alignment when reassembling,its supposed to be on the end of the crank and on the drive disk...right?
Mike M
01-16-2007 11:34:30
 Re: J.D. 730 Clutch Disk Drive Removal in reply to Fireman, 01-16-2007 10:47:00
You can make your own marks but on that model it is not part of the balance it can go on anyway. Put a bolt back in the end of the crank and give it some whacks while you have the other jack bolts drawed up tight. You may even need to heat the hub while under pressure if it is really stuck.
machinery-man
01-16-2007 10:53:18
Clutch fork out of case? You'll have to tighten and rap the end of your puller. Don't hit the drive or you may fracture it. Those things just don't fall off. Get good pressure then rap the end of the puller.
