4320 VS 4020
Sam from WA
01-16-2007 10:34:45
Whats the difference between the engine block in a 4020D and a 4320? I know that a 4320 is turbocharged, but i can't tell any other difference.
Gerald J.
01-16-2007 14:33:51
 Re: 4320 VS 4020 in reply to Sam from WA, 01-16-2007 10:34:45
They are both covered in the same I&T volume. Its likely the 4320 has oil jets on the bottoms of the pistons to help keep them cool that the late 4020 doesn't have. Probably more oil volume just for improving the cooling. Is the 4320 injection pump driving from the front or rear of the engine? The 4020 pump is driven from the rear...
Gerald J.
WTW
01-16-2007 14:29:53
Sam, The biggest common things between the two engines are bore, stroke and displacement. The block is a complete different design/part and will not work to directly replace an original 4020 block. 4320 has injection pump driven off front timing gears verses camshaft/oil pump driven on 4020. No place to mount original 4020 injection pump on a 4320 block. Another big difference is water pumps bolt to the block on 4320 verses to the head on a 4020. Head is also different with bigger injectors. If you were going to swap a complete engine it can be done but clearance for fan and radiator get very challenging due to newer water pump location and length. Many options to consider if swapping complete engine and the first one would be the later 404 engine not the 4320 engine. If you are not wanting a turbo pick a later engine without as compression and parts are also different. Email me if you are looking for an engine or more information. DW
Doug in IL
01-16-2007 14:29:50
Two things I can think of right off are a higher capacity cooling system and better engine oiling system.
