How do I clean an engine block?
Scotty H
01-16-2007 08:09:03
I have a 6-1 power block that I would like to get cleaned up. I've read in the archives that power blocks shouldn't be put in the machine shop tanks because it will mess up the O-rings. Where are the O-rings at on the block and is there a secret to cleaning a block?
G/MAN
01-16-2007 16:01:05
 Re: How do I clean an engine block? in reply to Scotty H, 01-16-2007 08:09:03
I absolutely agree with Drew on this one. Shot-blasting and hot-water washing in a cabinet with water and detergent instead of being dipped in an acidic hot-tank will leave that block looking like new, and shouldn't harm any seals. I took a very grungy 350 Chevy block to be baked, blasted and washed and it came back looking like a brand-new block.
Drew
01-16-2007 10:08:13
If you are going to bore it anyway, find a shop that has a shot blaster. It wont get every bit of gunk out of the water jackets but will clean the outside very well. Some machine shops may have a spray cabinet instead of or in conjunction with a hot tank. I wouldnt think a spray cabinet would hurt it because the block isnt submurged in chemical.
There is a 1/16 o-ring on the top of the sleeve where the sleeve fits into the block and a bigger one in the back behind the sleeve flange at the back of the block.
Be careful with the sleeves at the back of the block, they are fragile!!
