3010 Oil Indicator in cold weather
Steve/IA
01-16-2007 06:59:53
I plugged in my 3010 Gas for a few hours before heading out to push some snow off the drive. It was -2 outside but the old girl popped right off. I was very impressed until the oil indicator did not go out. I let it run at 1500 rpm for a while thinking it was just really thick oil but after about 40 seconds I chickened out and shut if off. If I remove the wire from the sending unit while the engine is running the light goes out so I think that rules out a wiring problem. Is it possible the sending unit is stuck because of the cold?
I forgot to mention this tractor has an unknown number of hours on it(a lot).
Steve/IA
01-16-2007 07:56:49
 Re: 3010 Oil Indicator in cold weather in reply to Steve/IA, 01-16-2007 06:59:53
I assume any mechanical oil gauge from the auto parts store would work so I'll give that a try. I am running 10W-30. The temp is normally not this cold when I need to use it. I have a magnetic heater I usually put under the battery box to give me a little more cranking power but I should have put it on the pan at this low temp.
I might try to hit the sending unit with some warm air for a while to see if that would help but I checked JDParts and a new switch is a little over $13 so I might just pick one up. I would have looked at it a little longer but the cold has to much for me.
Thanks guys!
Bob
01-16-2007 07:21:28
Connect up a temporary mech gauge (1/8" pipe thread), and see what's going on, or try a new sender... DEERE # AT85174 , @ about $15.00.
Mike M
01-16-2007 07:10:49
Got a gauge to stick in the hole and test for pressure ? Maybe you can pull the sender and warm it up and put it back in.
Roger in Iowa
01-16-2007 07:09:50
What weight of oil are you running? If straight 30 It might not want to move. Put a heat lamp on your oil pan to warm up the oil and try it for a short time.
I don't know if you could have shearred off the oil pump drive or not? Don't know how it is driven. I would guess it is possible for sender to stick. Can you put in a gauge where sender is located?
I run 10W-40 year round in my gas 3020. Don't have enough snow to mess with so cannot say how long mine takes for light to go out.
Roger in Iowa
