62' 1010 SHIFTING PROBLEMS
MPDTRIPP
01-15-2007 19:51:52
I CAN CRANK IT UP WITH THE CLUTCH DEPRESSED AND IN GEAR WITHOUT IT TAKING OFF, BUT ONCE I LET OUT ON THE CLUTCH I CAN NO LONGER GET THE CLUTCH TO DISENGAGE. I'VE TRIED ADJUSTING THE CLUTCH WITH NO LUCK. IT DOES NOT SEEM THAT THE CLUTCH IS FROZE UP OR IT WOULD TAKE OFF UPON CRANKING..... ANY IDEAS
Sam from WA
01-16-2007 10:16:01
 Re: 62' 1010 SHIFTING PROBLEMS in reply to MPDTRIPP, 01-15-2007 19:51:52
Try splitting the machine so you can get at the clutch. its probably a bit rusty. clean up the flywheel and the pressure plate good and inspect the clutch disk for any damage. i had one that the flywheel rusted on, the clutch would not disengage before putting into gear to go to work. hope i was of help
MPDTRIPP
01-16-2007 14:54:03
 Re: 62' 1010 SHIFTING PROBLEMS in reply to Sam from WA, 01-16-2007 10:16:01
THANKS.....I"M GOING TO TACKLE IT IN ABOUT TWO WEEKS. I"LL LET YOU KNOW
