52'j.d. g engine oil
tim bynum
01-15-2007 18:43:20
can some one let me know the quanity of oil to put in my john deere g crank case and what weight.im in northern calif.also what is the oil filter number? napa? thanks for your time
Kurt_JDB
01-16-2007 06:48:58
 Re: 52'j.d. g engine oil in reply to tim bynum, 01-15-2007 18:43:20
Tim,
In the 1950's era JD service bulletins, John Deere released new oil specs for their old 2cylinder tractors because of the development of multigrade and detergent oils in the 50's. Using 10w30 or 15w40 should be fine. There is even a disscussion in one of the bulletins about how the detergent oils will appear dirty when in reality still serviceble because they hold engine gunk in suspension instead of allowing the gunk to build up in the engine.
Kurt
jd40an
01-16-2007 05:46:41
Takes 11 qts. with filter. Mother Deere probably has the best price on filter. I use 15-40 in all my 2cyl. JD's & also my diesels. Oil technology has improved drastically in the more than 1/2 century since the oil specks for these tractors was printed!
jdhbag
01-15-2007 19:16:57
11 us quarts, filter AR26350....$3.98 at mother Deere. I use straight 40 wt in mine here in VA of course it doesnt run in the winter Manual says 32degrees to 65 degrees F 30 wt.
430WLPG
01-15-2007 19:12:24
11qts of 30wt. the Fram # is C139PL
tim bynum
01-15-2007 19:17:29
 Re: 52'j.d. g engine oil in reply to 430WLPG, 01-15-2007 19:12:24
thanks for the info. i will get the parts tomorrow. thanks,tim
