DLTX63 carb.
bigtim72
01-15-2007 17:38:15
what is the best way to remove fuel nozzle on a DLTX 63 carb? would like to clean the carb really well don't want to destroy the nozzle thanks in advance for any help.
Glen in TX
01-15-2007 18:22:17
 Re: DLTX63 carb. in reply to bigtim72, 01-15-2007 17:38:15
Find a thread tap the size to tap inside of bottom tube and then put a bolt in and pull it out straight with slide hammer or something but try not to bend it. Don't push down on the angled part you see sticking out in top barrel or you'll bend and ruin it. If your nozzle has the angled bottom and tube soldered on side it's the gasoline nozzle but if not a all fuel nozzle.
Glen in TX
01-15-2007 18:39:56
 Re: DLTX63 carb. in reply to Glen in TX, 01-15-2007 18:22:17
If it's really stuck in there lots of penetrating oil and may have to heat the casting some but don't heat on the nozzle because if it's the gasoline nozzle you'll melt the solder off the side tube.
