2440 rear tire size interchange
Todd in AR
01-15-2007 15:38:16
The JD dealer in my area can't seem to help with my question. I am looking at a 1979 2440 that has 15.5x38 rear tire and wheel that has the rack-n-pinion rear axle width adjustment. Can the tractor be converted to the 16.9x30 size rear tire and wheel? Is there any internal difference (gear ratio ect.) of the tractor between the two tire sizes?
Tx Jim
01-16-2007 05:56:14
 Re: 2440 rear tire size interchange in reply to Todd in AR, 01-15-2007 15:38:16
Todd,the dealer must not want to help you. I looked on JDParts.com as you can also do and the gear ratio is the same for 28 in tires and up. Pinion is 9 teeth and ring is 43 teeth. Gears in tranny appear to all be same for all size tires. One question: why do you want to change to 30 in rears? Tx Jim
Todd in AR
01-16-2007 07:24:05
 Re: 2440 rear tire size interchange in reply to Tx Jim, 01-16-2007 05:56:14
Thanks Jim. I want the shorter tires for the lower profile (lots of steep hills here so the lower center of gravity the better for me) and also their width I"ll be using it primarly for the loader so the wider tire will give me a wider footprint for traction.
