throttle handle
gmc ronnie
01-15-2007 12:26:21
is there anyway to tighten the drag on the throttle handle so it does not slide back , the shutter handle is ok , the tractor is a 1949 jd b . thanks
gmc ronnie
01-15-2007 14:08:54
 Re: throttle handle in reply to gmc ronnie, 01-15-2007 12:26:21
thanks mike i'll have to try that , when i put the shafts together a while back , i put grease on the end so it would turn easy , i'll try the brake cleaner method .
Mike M
01-15-2007 13:06:21
Down at the bottom of the column that throttle lever piece has a taper on the bottom of it that may have too much oil on it. Lift up the throttle lever with a prybar/screwdriver at the bottom it should have decent spring tension on it. Then spray some brake cleaner in and around that taper then it may stay put. Or if you have no spring tension then thats the problem and you may need to figure out why you don't.
