'30 GP front wheels
jd30gp
01-15-2007 11:57:51
I cant get the front wheels off my GP for sandblasting. After removing the hub cap and retaining nut, an inset washer seems to be locking the wheel bearing assembly. How do I proceed?
Chooch
01-15-2007 14:44:40
 Re: '30 GP front wheels in reply to jd30gp, 01-15-2007 11:57:51
jd30gp,
I have had this happen on a couple of GP"s. The inside of the bearing is stuck on the spindle. There is no easy way I have found to break them loose other placing a block of wood against the inside of the wheel hub and "tapping" with a hammer. Usually with the correct angle of the tongue, a little perspiration, some persistence and a few choice words, they will come off. Chooch
40 JD G
01-15-2007 14:41:20
After you have the big nut and the washer off, it should pull off. You may have to bump it on the back side to get the bearings to move.
