How To Reassemble Hydraulic Pump?, Need some input
Ravgardner
01-15-2007 10:54:18
I've taken the PTO powered Hydraulic pump off of the 44 A to try to identify and stop an oil leak. This is the first one I've taken apart and was surprised to find there was no gasket between the pump housing and the rear end plate of the tractor. Looks like it metal to metal seal. Any advise about putting gasket sealer or copper coat or something on these surfaces before putting it back together?
ronbinco
01-15-2007 15:48:23
 Re: How To Reassemble Hydraulic Pump?, Need some i in reply to Ravgardner, 01-15-2007 10:54:18
I use Permatex aviation gasket cement with good results.
machinery-man
01-15-2007 14:03:45
Even torquing of the bolts is also the key. I've always liked the coppercoat but anything thing that produces a light tacky suface would work....a gasket would produce clearance and could blow out under pressure....
machinery-man
01-15-2007 14:03:26
Maark
01-15-2007 11:56:09
If you look at the lower housing with the gears in it, you will most likely find that the 1 inch thick center housing is cracked.
Mike M
01-15-2007 11:22:35
The book says schellac I have used a VERY light coat of silicone with real good results. Remember VERY light !
