1010 Sparkplug Wires
Poppy
01-14-2007 19:31:33
Can someone tell me where the sparkplugs go into the distributor cap? If you are looking down from the top, which location is number 1? The one at 4:00 or 7:00 or neither of these? Also, what sparkplug would be best for the 1010?
Henry M
01-15-2007 05:33:49
 Re: 1010 Sparkplug Wires in reply to Poppy, 01-14-2007 19:31:33
poppy
Getting back tyo your question. Where no 1 is depends on how and who set up the dist last. Now if you havn't moved the dist around or had it out?
Ya gotta bring the no one cyl up to tdc on the firing stroke. Drop the rotor on the dist and then look how the cap would fit down on the dist. The rotor should be pointing to which hole in the cap is the no one. then plug in the rest of the wires according to the firing order.
to set it closer for startup if ythings have been moved. Loosen the dist and with the no one still up on firing stroke, slowly rotate the dist back against the normal rotation until you can see the points just starting to brake. snug it down there.
Also the inner shaft wil rotate inside the outer. So you have to keep the inner shaft snugged back against zero advance when doing the initial set up. It should start and be pretty close.
buickanddeere
01-14-2007 20:52:08
Replace those wires with solid core instead of fooling around with the old carbon core type. An Autolite 216 or the warmer 473 will do. There is a platinium version of the 216 however the number excapes me.
