4010 pto rpm
Darren K
01-14-2007 19:17:00
I think my pto is set at 540, i have a mohawk 8ft twin bushhog. Is ther any way to tell if this mower is a 540 or 1000 rpm machine? Can you change the speed to 1000 on the pto of a 1964 4010?
Fern(Mi)
01-15-2007 16:11:37
 Re: 4010 pto rpm in reply to Darren K, 01-14-2007 19:17:00
Word of caution. Changing the 540 pto shaft for 1000 pto shaft requires a gentle hand wiggling or working the 1000 pto shaft into place before replacing pto shaft bolts. If force is applied to bolts to pull pto shaft into place will shear small pin in pto shaft up front. replacement this pin requires spliting tractor. So, take heed, my words. Have had to fix our 4010 twice after some know-it-all took the wrenching shortcut. Fernan
dynaflow
01-14-2007 19:51:34
I don't know the rpm of your cutter but you should tell by which spline it uses on the pto. A 4010 can be used either as 540 or 1000 rpm by changing the short splined shaft that is bolted on with 4 small cap screws. By unbolting the 540 splined shaft and bolting on the 1000 splined shaft it shifts the gearing internally to run the right speed. This is done by the small pin sticking out of the tractor under these short stub shafts. The front pto on the 4010 will run at the same speed as the rear. a 4020 has the front pto running at 1000 rpm all the time.
