Engine Binding - 48 A Rebuild
Sam in MN
01-14-2007 13:59:13
Just put in the .090" over pistons and it appears to be binding when I turn it over by hand. If I torque the connecting rods to 90 lbs, you can't get her to turn over even with a prybar in the flywheel. Has all new bearings, rods and crankshaft have been babbited and ground back to std. Machine work was done by Lloyd's Cylinder Head in Rogers MN. and they have done two-cylinders for 30 years.
Looks like the connecting rods are both binding on one direction. The gasket kit came with a gasket for the right main bearing housing, between the housing and the main case. So I put it in. Could that cause the crankshaft to be pulled to the pulley side by 0.010 to 0.015" and be causing the binding?
Could the side adjustment on the crank be off? Didn't put the clutch and pulley on yet, maybe that could be the issue?
Or could the rods be in backwards? Is there a way to tell up, down, left or right? They were stamped on top 1 on left and 2 on right side, which is correct. But who knows if they were in right to begin with.
Any help would be greatly appreciated.
Sam
Mike n Mo
01-14-2007 14:42:05
 Re: Engine Binding - 48 A Rebuild in reply to Sam in MN, 01-14-2007 13:59:13
1st, can I assume that you have the rod caps matched to their respective rods, and the numbers all are up? Did the machine shop re-shim the rods for proper clearance or leave that to you? Get some Plasti-gage and check it. It should be available at most any auto parts store. According to the parts book, I don't see a gasket for the right main bearing housing, and I've never seen one in the A's I've had apart. There should be one between the left M.B. housing and the crankcase. Crankshaft endplay is controlled by the flywheel, having the clutch off shouldn't make any differance.The suggestion to ensure the crank turns easy with the rods out of the way is good, it will tell you if the bind is in the mains, of the rods, or it could be both. Post back if you need more info. Mike
DRL
01-14-2007 14:27:33
Did you just slap the end caps on the rods and torque them down, or did you use shims and plastigauge to get proper clearance? Did you check to be sure that the journals on the crank were true? Even on a reground, it is a good idea to check to be sure. Babbit rods are shimmed for proper clearance. Sounds to me that you need to check clearance again at several different points. Do one rod at a time and check for drag as you go around. Seems like there was a post from someone who knew what they were talking about that said to add shims until you don't feel the drag, then add another set of .003 shims and you should be good.
Sam in MN
01-14-2007 14:51:12
 Re: Engine Binding - 48 A Rebuild in reply to DRL, 01-14-2007 14:27:33
DRL,
Yes I did check the clearance with plastigage and they are both between 0.003 and 0.0035 at 90 lbs. torque I did not check out of round though.
The flywheel could be turned over by hand before I connected the rod journals. I was tight but not that bad.
Both Pistons do look like they are angled to the right (Pulley Side). So I wonder if that oil slinger is not seated properly and is pushing the crankshaft to the right side. I am still leaning towards the crankshaft side alignment as the problem.
Mike n Mo
01-14-2007 16:29:30
 Re: Engine Binding - 48 A Rebuild in reply to Sam in MN, 01-14-2007 14:51:12
Just a thought, If the crank was reground, I would assume that the camshaft drive gear was off. Is it fully seated toward the clutch side of the crank? Is it oriented correctly? The side with the teeth at the edge should be toward the clutch side. Mike
Sam in MN
01-14-2007 17:14:05
 Re: Engine Binding - 48 A Rebuild in reply to Mike n Mo, 01-14-2007 16:29:30
Mike,
Not sure as I did not remove that gear amd it came back just as I left it. I can surely check that and make sure it is seated tight to the right side. It meshed up with the cam gear, s I would have to assume it is oriented correctly.
Too cold to go out tonight, but I am vidsualizing the flywheel side and potential issues there. I did not punch mark the flywheel spacer and crankshaft before removing, for orientation during reassembly. It has the square notch in it, that mates up with a square pin on the inside of the flywheel. Plus the crankshaft has a screw in the splines that has to line up with a specific spline in the flywheel. So could I have something screwed up there, which is forcing the crankshaft hard to the pulley side? I loosened up the nut on the outside of the flywheel after tightening it down eariler and now I can't seem to get any end-play in the crankshaft. Loosened the Flywheel to the point it wobbles and still no endplay in the crankshaft.
Hummmm???
machinery-man
01-14-2007 14:14:12
Sam: you post would leave a smorgassboard of possible problems. I would suggest the following. Remove the connecting rod caps and allow them to be out of the way. Then see if you are binding. If so you have an end play problem or maybe the oil slinger is not properly seated. I always see that engine is free as it goes together and always have the flywheel on first.
