D running rough
Kevin
01-14-2007 11:53:46
My 49 D is running rough, she only wants to run at one rpm, doesnt seem to want to throttle up or down, it will throttle up but she sets right back down to its own prefered rpm. Im thinking its probly governer problems but im going to try lubing up all the linkages and carb tunning first just to make sure. I was wondering what some decent setting are to start at on the carb.
Glen in TX
01-14-2007 13:23:30
 Re: D running rough in reply to Kevin, 01-14-2007 11:53:46
For running gasoline in it about 3/4 to 1 1/4 turns open for idle needle and about 3/4 to 1 turn open for load needle. Also adjust the throttle rod from governor to carb by pushing throttle lever forward to full throttle and then slide rod out at carb throttle lever and adjust rod till it is a 1/2 hole short of going back into carb hole while holding carb butterfly rod to full open position.
