1937 Unstyled A Clutch Question
Steve Kelly
01-13-2007 17:49:27
On My Unstyled A the Clutch Fork Bearing Is loose when you work the clutch lever back and forth. Can someone tell me if one off of a 1941 styled a will work I have the part number is a A21R and the Clutch fork shaft is a A603R Are they the same they sure look the same but could not read the numbers. Thanks for any help.
las vegas
01-13-2007 20:50:55
 Re: 1937 Unstyled A Clutch Question in reply to Steve Kelly , 01-13-2007 17:49:27
chances are the one you are looking at is worn too. I just had mine machined with a new bushing in the bearing and the fork shaft built up with weld and turned down to original size above the splines. It's unbelievably tight. I also did the pulley brake which was pretty floppy, too. now it hangs right where its supposed to be. cost me 60 bucks at a small time machine shop.
