HELP! 2 questions re: 36 B
CalJim
01-13-2007 13:49:47
First question:
How do you install the rivets that hold the
brake shoes? Can"t get them to draw up tight.
I do have the correct rivets.
Second question:
Do I need to use a DLTX 10 on the 36 B?
The one I have seems to have some issues.
I do have a 34 and a 67 on the shelf,
they were both rebuilt by Roberts. The 67
actually came off the B when I disassembled
it, sent it to Roberts assuming it was a 10.
(the tractor was not running when I got it)
Don"t want to make this confusing, bottom
line can I use a 34 or 67 instead of a 10?
Thanks everyone CalJim
Kurt_JDB
01-13-2007 16:40:55
 Re: HELP! 2 questions re: 36 B in reply to CalJim, 01-13-2007 13:49:47
As Pat said, this job is best done with two people, but it really is pretty simple. Here is how I did it, and this is from advice I got on this board:
Get a flat headed punch with a head about the diameter of the rivet head. Put this punch in a vice pointing up. This will be your anvil.
Next get hold of a transfer punch. I think 5/16 is the right size. I got a whole set at harbor freight for $10. a transfer punch has a cone shaped head with a bench at the bottom.
Get someone to hold the brake shoe/lining/rivet assembly oriented so the rivet head is resting square on the punch that you have in the vice.
Set the pransfer punch on the open end of the rivet and tap the punch lightly until the rivet is set. The cone shape of the transfer punch will nicely fold the rivet over.
The only real trick is to know when to stop tapping. Too tight and you will crack the new lining.
Good luck to you.
Kurt
P Browning
01-13-2007 14:59:53
CalJim -- The DLTX-34 is also from the all-fuel era of JD-B tractors, and you would have the best chance of success with that one. I would give Robert a call (Robt's Carb) and see what he thinks. I cannot think of anyone who would know the actual differences better than he.
On your brake rivets, proceed ever so carefully. Even with the right tooling, this is a two-person job. And the holder must have total confidence in the one with the tools or failure will loom large! The KEY is to deliver impact ONLY to the rivet.
I was spared the rivet experience when my supplier sent brake facings that fit the shoes alright, but not the hole pattern -- way off. And so I used JB Weld as an adhesive and the drum as a tool along with a vise grip and C-clamp to hold the shoe with facing in place inside the drum, & placed out to the drum's very edge. They look & fit superbly, and I believe they will do just fine. (PatB)
old
01-13-2007 14:10:51
When I was getting my 1935 B up and running I was told I had to use the DLTX 10 on it or it would never run right. My B is a all fuel which I also figure your is. From what I understand the other carbs have bigger jets etc. and will not work well. I maybe wrong but thats what I have always been told so I wnet with a DLTX 10 on mine and have never looked back.
