Oil pump in Unstyled A
37JD A
01-13-2007 08:57:51
What is the acceptable oil pressure to expect in my 37 JD A tractor? Should I expect it to get to the Medium level? Also, isn"t there an adjustment screw to increase the pressure? Thanks-
37JD A
01-14-2007 15:37:37
 Re: Oil pump in Unstyled A in reply to 37JD A, 01-13-2007 08:57:51
Is that 10-15 psi at high idle?
I put a new JD oil gauge on, but it only has the L-M-H indicators. Right now it is running a little above L at high idle.
Glen in TX
01-14-2007 13:38:50
You can install a known good numbered oil guage and see if pressure is around 10-15 psi. If not then yes there is a adjusting set screw inside crankcase on top of the filter head and should see another bolt to loosen some to allow set screw to be turned to get 10-15 psi and then retighten bolt clamping set screw. Crankcase cover on top has to come off to get to it.
