Gas in oil
Tim Bucktoo
01-13-2007 05:17:32
I have an 80 and when I fire up the pony I get some smoke out of it. The oil smelled like it has gas in it so I drained it and put new oil in it. Now it doesn't smoke nearly as bad. My question is someone has put a diaphram valve on it and I wonder just how good are these at keeping the excess gas out of the pony? I bought an original shutoff valve and I am thinking of putting it in since it would positively shut the flow of gas off. Am I correct in thinking that these diaphram valves were a convenience to the operator? I would think that after closing a manual shutoff valve, running the engine until it quit, then turning off the ignition would be the surest way of keeping excess gas out of it? Any thoughts?
DIESEL MAN
01-14-2007 07:42:08
 Re: Gas in oil in reply to Tim Bucktoo, 01-13-2007 05:17:32
well the problem lies on how you are shuting the fuel off you need to shut it off then let the engin shut off that way. then shut the ele. down... now that u have found gas in the oil now u need to drain both of the oils the big diesel motor and the pony then put fresh in...
Hayfarmer
01-13-2007 18:20:08
I believe that was one of the problems on these pony engines, why folks had problems with them, that gas kept running after the engine shut down and went to crankcase or just filled up the cylinder. With a good shutoff and running it out of fuel each time it should aleviate that problem.
super99
01-13-2007 14:59:35
Go to tractor talk page and scroll down, look for post about pony's. Most agree that you should shut off gas and run dry, and change oil often. Chris
