Bolts and Misc.
mark
12-27-1999 17:42:49
CORRECT CONNECTION 3345 Copper Kettle Highway Rockwood Pa 15557. 814 926-2764 E-Mail [email protected] A great place to get all your hardware needs to properly restore your JD. Radiator bolts to fuel tank webbing,battery box kits. It might take a couple of weeks to recieve your order, but worth the wait. Give em a try.
Huckleberry
10-26-2003 08:14:01
 Re: John deer 45 combine in reply to andy, 10-25-2003 09:48:01
I have an old 1959 JD 45. It has a 4 cylinder Hercules gas engine. I don't know the hp...45? maybe. These machines will do anything the 100000+ dollar outfits do...that is...you can harvest your crop. not so fast---NO COMPUTERS---whoa! You may have a problem with some of the parts but there are still a few good machine shops where you /for a price/ can get them made.
Joe Duling
10-26-2003 08:00:19
 Re: Re: Re: Re: Re: !HELP! 46 A runs on 1(this is in reply to AC, 08-15-2002 19:22:08
If he bent a push rod there's has to be reason why. I would check the rockers if they are free or the timing. I had one just like that but sold it after I got it running. When I started it for the first time I had bird feathers come out of the exhaust.Talk about laugh that was a worth a good one. Then it only ran on one cylinder. I found that the other rocker was rusted fast to the rocker shaft and the push rod bent the rocker in half. I found another rocker polished the shaft that fixed that problem. It ran good after that. I also have a 1944 B I could never get it to run smooth. I replaced the carb new plugs,wires thought I had it but I was wrong. I thought I would look at the electrical a little more. I cleaned all the contact points in the mag cap and the points with fine sand paper. It ran like a charm after that. That gives you a good feeling when you find the problem. What made me look there was it would run on one then the 2nd would fire every so often. So I pulled the plug wire of the good one then the second one ran perfect. That told me the problem had to be in the mag. Good luck but don't give up.
