4430 engine rebuild
superfarmer
01-12-2007 18:59:45
Doing an inframe on the 4430, wondering what piston kits are the best for power and cold starting. No major failure, just losing compression and hard starting. Thanks
G/MAN
01-15-2007 07:43:17
 Re: 4430 engine rebuild in reply to superfarmer, 01-12-2007 18:59:45
More important than the kit brand is making sure the cylinder head is done right. Excessively sunk valves increase the volume of the "chamber" and can lead to low compression and hard starting. The valves need to be up to the proper protrusion spec when the head is redone. A machine shop that does a lot of diesel work will know this and make sure it's right, a machine shop that does mostly car engines and the like may not. Personally, I'd stick to Deere parts. I've gone back into engines that were rebuilt with Brand X kits and wasn't impressed - grooved main bearing shells in the caps where Deere kits use non-grooved full shells for more bearing area, etc. Also make sure to use JD Break-In oil in the new engine and dyno it at full load for several hours. The new diesel oils are getting so good that they won't allow the initial wear necessary for a good break-in, and seating rings requires heat and power. We run all new overhauls a minimum of 4-5 hours at full load. If you don't, you're just asking for a low-compression, oil-burning, wet-stacking mess, particularly if the tractor isn't going to be worked hard after the overhaul. We run Break-In oil for 100 hours, then dump it and run it for another 100 hours. You don't want to exceed 100 hours because the same lack of additives that allow good break-in also let the oil break down more quickly. The Break-In oil is also a little thinner oil.
JD NY
01-14-2007 19:54:16
Won't hurt to look at the high compression kit from A&I. The higher compression will help with starting and give a bit more power. A&I is owned by Deere and a lot of the parts Deere sells are made by A&I. Not sure where Deere gets their kits from but it could be from A&I. I have a 3020 and 4020 that have these kits in them and they are great.
donmyeil
01-13-2007 13:45:34
Check the oil pump gear to camshaft for wear. these can get pretty sharp and a failure could wipe out the engine . I would stay with Deere. used to get a 90 day parts warrenty but dont know if thats true anymore. have the injector pump and nozzles run as well. Don
Kent Petersen
01-13-2007 04:49:58
I have used Reliance kits on many 4430s very good parts always install new rod bolts when overhauling deeres, valve seats a must to get good starting good luck kent
superfarmer
01-13-2007 16:01:16
 Re: 4430 engine rebuild in reply to Kent Petersen, 01-13-2007 04:49:58
i see reliance has a hyper-formance kit listed, any experience with them? Or Pow'r Seal pistons? Thanks, reliance seems to be the more reputable of the aftermarkets, and I'd pretty well bet the kit from Deere is made by one of the aftermarket companies too!
MSM
01-13-2007 03:58:25
A Deere or Clevite kit will give good results. The majority of the hard starting is due to the valves sinking into the seats,or the seats worn.Have the head rebuilt by a reputable machine shop that will do the work properly to Deere's spec.It will probably take a set of valves to get it in spec. Grinding the valves and seats only will worsen the cold start problem.
msb
01-12-2007 19:34:58
I guess its a matter of personal preference , but I will only use Genuine Deere after getting an off brand kit with rusty wristpins.
Be sure to have the rods checked. They are well known to have a stretching problem.Machine shops can rebuild them and it doesn't cost very much if they need it.
