4555 MFWD front axle seal?
John e.c.MI
01-12-2007 16:21:04
I have a seal leaking on my 4555. I bought a service manual on ebay but it doesn"t cover the front seal R&R. What is involved in doing this?
Bob
01-12-2007 23:05:38
 Re: 4555 MFWD front axle seal? in reply to John e.c.MI, 01-12-2007 16:21:04
Inner driveshaft seal, or hub seal or input shaft seal?
Hub seal is key #25. If that's what's leaking, you take out the 4 capscrews, #19, drop off the outer planetary assembly, and drive axleshaft, then undo the bolt locking the bearing retainer, and unscrew it. Then, the hub can be removed, much like a truck hub.
Third Party Image
Inner driveshaft yoke seal is #5 in the drawing below. To get to it, you do the above, then remove the outer knuckle.
Third Party Image
Does this help???
Oh, yeah, and BE CAREFUL... get the front supported SAFELY!
John e.c.MI
01-13-2007 05:39:32
 Re: 4555 MFWD front axle seal? in reply to Bob, 01-12-2007 23:05:38
Thanks Bob, that was the seal I was talking about.
