630 steering worm
fixerupper
01-12-2007 15:56:14
Just posted a picture of the steering worm from a 630 with power steering, in parts & pieces. Couldn't figure out how to get it here from Photo Bucket yet. Anyway, the slot in the end of the worm that engages the dowel pin in the actuator sleeve, appears to be worn to the side, at least I don't think it's supposed to be that long. This is the first time I've had one apart, so I need help from the experts. I'm thinking the slot should only be the width of the dowel. Thanks, Jim
machinery-man
01-13-2007 06:18:29
 Re: 630 steering worm in reply to fixerupper, 01-12-2007 15:56:14
I've always found the dowel pins to be more of the problem. You can remove and turn around and replace. They wear a flat spot. Anyway like Mike said these parts are scarce and you might build up and grind down. Most all the old stuff I just try to get it centered in the wear. There is no way to make everything new but adjust the part for wear. The screw also wears and I've used a small grinder and file to true up the screws.
Bob
01-12-2007 16:12:36
The slot is wider than the dowel as there is movement as the dowel moves on the ramp, to actuate the steering valve. Your's looks kinda tough, though!
Third Party Image
fixerupper
01-12-2007 16:30:29
 Re: 630 steering worm in reply to Bob, 01-12-2007 16:12:36
I apologize for the not-so-clear picture, but this was the best one of the bunch. I have a hunch the slot is not supposed to be shallower on one side than it is on the other, like it is now. It goes a little past the keyway. This is a 15000 hour tractor with 35 years of loader experience. Jim
Mike M
01-12-2007 18:23:52
 Re: 630 steering worm in reply to fixerupper, 01-12-2007 16:30:29
If I had a clear picture I might be able to help you better ?
I have had alot of those have the end of that slot broken off and had to have it welded up and ground it out with a dremal. I can't see yours. You have to trial slip fit the other piece in there and then run a new pin through the slot and make sure it is even all the way through.
fixerupper
01-12-2007 18:52:53
 Re: 630 steering worm in reply to Mike M, 01-12-2007 18:23:52
Just put another pic on parts & pics. I hope it helps. I have no problem with building it up, I just need to know the proper fit. Thanks again. Jim
Mike M
01-13-2007 05:06:42
 Re: 630 steering worm in reply to fixerupper, 01-12-2007 18:52:53
Finding another one may be tough to do as most may be just like yours. This was a poorer design than the earlier one. Deere called it an improved design ,but it was not. Check inside along the key way for being split I had one that was once and scrapped it the rest I fixed. You need some real good hard welding rod as that steel is hard. A file shouldn't touch it only a grinder. You just have to fit it by hand using a pin in the hole and the other half to guide it you will see that the pin when it comes to the end was surrouned by metal,the end that breaks is fairly thin and the pressure is put in a small area so they can break. The pin need to slide equally through the whole range of the slot,hold the side play as exact as you can as this is where the power steering working area is. The ends are for when you go into manual steering mode. If you can find a good used one it may be best because if this binds up when going down the road it can become a matter of life and death. You have to make the call. I have repaired several of varing degrees of broken out and have been able to get them back working again. I also trial fit everything together out of the housing and check the adjustment so the outer sleeve can rotate/slide in that groove( when the worm is held still )freely without binding and the spring returns it back to the center and at the minimum end play all along it's travel. Do you have the JD copy of the power steering service manual. This is a must have if you don't. It may even show some decent pictures of what new parts looked like way back when.
Bob
01-13-2007 11:44:30
 Re: 630 steering worm in reply to Mike M, 01-13-2007 05:06:42
Mike M,
Is my memory correct in that the "slot" is also a "ramp"... in other words the slot is NOT perpendicular to the shaft axis, but at a slight angle, which pushes the PS valve to the front or back, depending upon which side of the centerline of the slot the pin is in?
Mike M
01-13-2007 11:54:22
 Re: 630 steering worm in reply to Bob, 01-13-2007 11:44:30
Yes, you and I are on the same page. Your description of a ramp is a good one. It takes alot of time and good old hand labor to get them ramped up right and tight again without binding.
fixerupper
01-13-2007 06:28:01
Thanks for the advice. My first inclination is to try to fix it, cuz I kind of get a rush out of the challenge of fixing something intricate. I do have access to the manual but the pics arent at the right angle to show the slot. The danger of binding is very real. A few years ago a young man was driving this tractor down the road and after he went around a corner he couldn't straighten out again because the steering locked. We have deep and steep ditches and he started going in the ditch so he tried to jump but his clothing cought so he went along for the ride and steered it back up on the road. If it wouldn't have been for the wide front, weights in the rear wheels and the 1300 lb cement weight hanging on the 3 point, the tractor would have gone over on him. That was five or six years ago and it still scares me. Jim
Bob
01-13-2007 11:46:46
 Re: 630 steering worm in reply to fixerupper, 01-13-2007 06:28:01
If the steering locked that severely, I would also completely disassemble the front pedestal, and check out the "vane motor" that does the actual power steering. Bolts and other things break in there, and cause SEVERE lockups of the steering when they jam things up!
