4020 weep holes
Reaver
10-29-2003 19:14:21
Just read something about weep holes in block on 4020 leaking antifreeze.
My father has a 4020 diesel and says that sometimes it looks like small amounts of antifreeze come out of small holes in block?
What is this and is it a big deal?
Thanks for comments.
Reaver
buickanddeere
10-30-2003 06:15:42
 Re: 4020 weep holes in reply to Reaver, 10-29-2003 19:14:21
If you are going to drive till it drops. Drain and flush the coolant and fill with distilled water and propylene glycol. Not ethylene glycol. Should there be a leak into the crankcase the bottom end won't be ruined. And pets won't be killed licking up antifreeze.
G-MAN
10-30-2003 04:55:25
Although it is common, it's NOT normal, and is an indication of a potential major problem. As was posted, the holes are located in a groove between two o-rings that seal the liner. The upper seals coolant, and the lower seals oil. Providing that the wholes are open (many are plugged tight by years of gunk), coolant escaping past the upper o-ring will exit those holes before trying to force it's way past the lower seals, which it WILL due to the greater pressure in the cooling system than in the crankcase. The holes were basically a safety, and Deere used them because the New Gen engines were a brand-new deal for them, and they were using wet-sleeves for the first time. After they had gained experience with them, and had liner sealing down to a science, they eliminated the holes. Will the tractor be okay the way it is? Probably, at least until an o-ring fails big time, at which time you may get more leakage past the seals than the holes can release, which will allow anti-freeze into the crankcase. Not a good deal. At the very least, use a piece of wire and make sure all the holes are completely free of crud. But, do NOT blow comressed air or high-presure water into them. The correct fix would be to remove the sleeves and replace the liner seals.
Dan
10-29-2003 20:20:10
Believe it is just a small amount of anti freeze that gets by O ring on liner. Weep holes are so that it goes to the outside instead of going on down into the oil. Don't hink a small amount hurts and is normal, especially when tractor has some hours on it.
Bryan
10-29-2003 19:34:29
Mine weeps a little bit. When I asked a friend of mine ( who is a mechanic at a JD dealer) he said that it is nothing to worry about. I haven't had any problems with it.
