JD 2010 Will not Turnover - Acts Dead.
Blueclawz
01-11-2007 18:06:31
We just got a gas 2010 widefront in and outside of some light cosmetic work its a nice piece. The rubber is nearly new..it has tons of hydraulics including an extra set of outlets?
It will not turn over...you turn the key.it makes a single CLICK" and thats it..the dash lights up. It has a 12v battery in the tray and the ground strap is fastened to the NEG terminal. (I think this could be wrong - but nobody can confirm)It has fuel..but I cannot even get the starter to turn over...tried bumping the ignition a little with no result.
Help me save this tractor from the "scrapper" - I can buy it cheap but I want to know its a fixable issue. Previous owner states it ran fine in the summer..but started having "sporatic" electrical issues (no specifics). I only have until NOON tomorrow to take the leap....
billde
01-11-2007 19:36:28
 Re: JD 2010 Will not Turnover - Acts Dead. in reply to Blueclawz, 01-11-2007 18:06:31
Pull start it, find out what other issues it has before you waste time on a starter. 2010's can be a nice little tractor, or the biggest pain in the a$$ you've ever owned. Starter problems are cheap and easy to fix compared to whatever else could be wrong.
Bob
01-11-2007 19:10:00
First of all, be darned carefull and be SURE the transmission is in "park", so the tractor doesn't run you over if it suddenly cranks and starts while you are working with the starter and wiring.
They were (+) ground, at least through serial # 42,000. I'm not sure after that. Battery polarity will NOT affect the operation of he starter.
Third Party Image
If you just get a "click" out of the solenoid, the battery could be weak or defective, either battery cable could have a poor connection at each end where it attaches, or even between the battery cable and the terminal attached to it.
Two starters were used, Prestolite and Delco. Either could have a bad solenoid, or internal problems. The Prestolite had a really weird solenoid setup. HOPEFULLY, you have a Delco.
The starter drive COULD even be jammed against the flywheel ring gear.
Also, there is a neutral safety switch, IIRC, operated by the gearshift mechanism under the dash, #12 in the diagram. However, if the solenoid clicks consistantly, that likely rules out the neutral safety switch.
Put a test light on the large battery cable connection at the starter. If it lights, try starting the engine, and see if the light remains on (indicating the battery and cables are good).
If the test light remains lit AND the solenoid clicks, likely the solenoid or the starter is bad.
Here's the wiring parts diagram for the later ones, 42,001 and up. It's not as detailed as the one for the earlier units, in that the battery cable polarities are not shown.
Third Party Image
Hope this helps!
