JD 2755 Clutch
R. John Johnson
01-11-2007 11:57:24
Looks like its time to do the clutch on the old girl (AGAIN). The tractor spends most of it's life under a loader feeding round bales and I am getting about 4 years out of a clutch. Talked to the clutch rebuilder and he says we could put in a ceramic buttons. Claims this will greatly increases clutch life, but would be harsher to operate. Anyone out there with any experience/opinions?
Thanks in advance
John
G/MAN
01-11-2007 13:49:52
 Re: JD 2755 Clutch in reply to R. John Johnson, 01-11-2007 11:57:24
The LAST clutch disk type you want to use in a loader tractor is a ceramic or metallic button clutch, unless of course you prefer to buy new flywheels instead of new clutch disks. The constant engagement and disengagement of the clutch during loader work while using a ceramic or metallic clutch will wear the flywheel and pressure plate out faster than you're going through disks now. The clutch disk material is harder than the iron in the flywheel and plate, and they'll wear first every time. Those clutches are designed for high loads and hard pulling that require a lot of clamping force, not constant cycling. 4 years of steady use out of a clutch in a loader tractor is not out of line at all. Clutches are wear items just like belts, tires, filters and so forth.
Mike M
01-11-2007 12:05:33
When I did the clutch in our 4020 I talked to the folks at BMD and they offered something in between the organic and ceramic it may be called a feramic ? I think it is to last better than the organic but not be as jumpy as the ceramic. It has worked good so far. I think there is also a kevlar option. I didn't get this for some reason ? one of them may of been you had to have super smooth metal surfaces for it to ride against.
Did they offer directional reversers in those 55 series utilitys like the older ones ? If so that would of been the way to go back when buying the tractor.
Mike M
01-11-2007 12:34:50
 Re: JD 2755 Clutch in reply to Mike M, 01-11-2007 12:05:33
I think your options may be limited on that model. A & I that now owns BMD shows a solid,5 button and 6 button. JD also shows the same and footnotes them as light duty(solid),meduim duty (6 button),heavy duty (5 button). Those solid organic linings do not hold up well to loader service (as you know)so you may want to try a meduim duty one.
R. John Johnson
01-11-2007 13:16:09
 Re: JD 2755 Clutch in reply to Mike M, 01-11-2007 12:34:50
Mike
Thanks for the info. JDParts shows only two that I see. One labeled light working conditions and the other heavy working conditions. Hopefully I will not be going that route and will be rebuilding the existing clutch.
John
