JD 40 Steering box
LDP
01-10-2007 17:50:41
I have a 1953 JD 40 with tricycle front. When I bought it the steering was loose, caused by a worn steering shaft coming from the box, upper steering shaft and coupling. I bought the parts on ebay to fix. Everything worked good except the 2 studs or pins on the new steering shaft will not work in the grooves on the worm gear, don't line up. I can not tell a part number on the old shaft becuase it was broken with an home made head that holds the studs or pins. Does any one know if there were 2 size shafts that had 2 studs. I don't know how to figure which shaft I need if there is 2 different ones made. Any ideas would help. Thanks!
4o also
01-11-2007 19:19:00
 Re: JD 40 Steering box in reply to LDP, 01-10-2007 17:50:41
I think he is saying that if your seial tag starts with 40T ******* that you have a single pin . I have had 5 model 40 all serial tags have been 40 ****** no T they have all had two pins I just bought A 40 model with a 40T on tag now Iam courious to now , lean something new every day
LDP
01-12-2007 05:01:30
 Re: JD 40 Steering box in reply to 4o also, 01-11-2007 19:19:00
My s/n tag just has 40 as the model not 40T, but it is a tricycle front.
40also
01-12-2007 16:30:10
 Re: JD 40 Steering box in reply to LDP, 01-12-2007 05:01:30
Yes all of mine are wide front they came from the factory either way ,. I think they listed them as 40 tricycle with wide front . some MT had factory wide fronts
jCarroll
01-11-2007 11:03:21
The first of the model 40 had a worm follower with only one "tooth". The two "tooth" model was a design change later on.
Is there a chance that you have the worm for the original design? The serial number of your 40T would be a very good clue.
LDP
01-11-2007 15:03:08
 Re: JD 40 Steering box in reply to jCarroll, 01-11-2007 11:03:21
The tractor s/n is 65445. I could not find a part number on the steering box, except the cover which is TA125999. Does the worm gear have a number on it? I guess it would have to be removed to see it.
