JD 2240
TJJ Weathers
01-10-2007 13:24:58
I have a hyraulic leak problem with the shaft that goes through housing at the rear of the tractor. What I call the swing arms one on the right and the other on the left which attaches to implements (part of the 3-point hook up system) Anyway this shaft goes all the way through the housing, a hard bushing then slips over the shaft for the arms to ride in.
I have replaced the plastic bushing and o-ring inside the housing, reinserted the shaft and still have a drip from both sides especially under a load. The only wear i see is where the hard bushing rides with under the swing arms that really does not go into the housing at any point. I was going to buy a new shaft but want to ask anyone for advice first. I measured the shaft and got readings of .875 in the o-ring area and the areas in the case portion. Any advice would be appreciated
JMS/MN
01-10-2007 16:14:27
 Re: JD 2240 in reply to TJJ Weathers, 01-10-2007 13:24:58
Sounds like load control shaft bushings- sometimes the shaft is also worn and needs R&R.
