JD 40 HYDRAULIC PUMP LEAK
pop
01-10-2007 08:57:39
Re JD 40s
The motor oil is increasing in crank case slump, at the same time oil in hydraulic system goes down. I think the hydraulic pump must leaking into engine. What else could it be? I have the IT manual, appears to be an o ring and a leather washer that would prevent any leaks in to engine. Have you ever done this job and is it a big deal?
Thanks pop
Thane
01-10-2007 09:15:50
 Re: JD 40 HYDRAULIC PUMP LEAK in reply to pop, 01-10-2007 08:57:39
I did this, almost 5 years ago, after noticing the same symptoms you described. You are right, it"s just a few parts, o ring, leather washer. The hardest part was getting to it. I took off the radiator, and worked my way back to the pump. Once i got the pump off, it was easy, and cheap, to fix it. I think parts only cost me a few dollars. Of course it took me a lot of time, but it wasn"t that hard to do.
